Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
论文类型 | 基础研究 | 发表日期 | 2014-10-14 |
来源 | Chinese Journal of Chemical Engineering, | ||
作者 | ZHAO,Changwei,(赵长伟),LI,Jiding, | ||
关键词 | polydimethylsiloxane (PDMS)/polyetherimide (PEI) composite membranes, sulfur removal, gasoline,pervaporation | ||
摘要 | Worldwide environment has resulted in a limit on the sulfur content of gasoline. It is urgent to investigate the desulfurization of gasoline. The polydimethylsiloxane (PDMS)/polyetherimide (PEI) composite membranes were prepared by casting a PDMS solution |
相关推荐
- Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
- Enhanced Biological Nutrients Removal in Modified Step-feed Anaerobic/Anoxic/Oxic Process
- Degradation of azo dye C. I. Reactive Black 5 by composite ferrate solution
- 阳极电势对Geobacter sulfurreducens 产电性能的影响
