Determination of diallyldimethylammonium chloride in drinkin
论文类型 技术与工程 发表日期 2006-03-01
作者 Fen,Jin,Jianying,Hub
关键词 Diallyldimethylammonium chloride Drinking water Ion-pair chromatography LC-ESI–MS
摘要 A method for the direct determination of diallyldimethylammonium chloride (DADMAC) in water samples, using ion-pair liquid chromatography–mass spectrometry system was developed. The chromatographic separation was performed using a C18 column. The type, th
