头孢唑林酸废水的纳滤分离及技术经济分析
论文类型 | 技术与工程 | 发表日期 | 2004-03-01 |
来源 | 《工业用水与废水》 | ||
作者 | 向连城,荆一凤,张雷 | ||
摘要 | 向连城,荆一凤,张雷 (中国环境科学研究院,北京100012) 摘要:抗生素类制药废水污染物浓度高,微生物不易降解,处理难度大。采用纳滤膜分离方法处理头孢唑林酸废水,通过现场实验,确定了工艺参数:料液温度25~30℃,pH值4~5,膜平均通量3L/(m2·h),膜前流速7 ... |
向连城,荆一凤,张雷 摘要:抗生素类制药废水污染物浓度高,微生物不易降解,处理难度大。采用纳滤膜分离方法处理头孢唑林酸废水,通过现场实验,确定了工艺参数:料液温度25~30℃,pH值4~5,膜平均通量3L/(m2·h),膜前流速7.14L/(m2·min),膜前压力3.0 MPa。并得到头孢唑林酸回收率为90.3%~93.7%。通过经济分析,得出不到2年时间即可回收全部投资, 因此认为纳滤膜分离技术在处理头孢唑林酸废水中的应用不仅技术上合理,在经济上也是可行的。 Nanonfiltration of Cefazolin-Containing Wastewater Abstract: In the waste water from the production of anti-biologic pharmaceuticals,the concentration of pollutants is high and the microorganisms are hardly degradable,which makes the treatment of the waste water very difficult.A separation process with nanofiltration membrane was used in the treatment of waste water from the production of cefazolin,the process parameters of which were measured as fo11ows through site tests:Temperature of feed liquid:25~30℃,pH value:4~5,average flux through membrane:3 L/(m2·h),flowrate before membrane:7.14 L/(m2·min) ,and pressure before membrane:3.0 MPa.It was also measured that the recovery rate of cefazolin was 90.3%~93.7%.It is believed through economic analyses that the total investment can be recovered within less than 2 years and,therefore,the application of the separation technology with nanofiltration membrane in the treatment of waste water containing cefazolin is not only reasonable technically but also feasib1e economically. 纳滤膜在工业中的应用开始于20世纪90年代初期,目前在我国也有少量应用。在制药及精细化工等一些行业中,纳滤膜分离技术应用于以清洁生产为目的的有用物质回收和以环境保护为目的的有害物质分离中。 1 抗生素废水分离浓缩试验 1.1 试验废水成分
1.4 工艺条件选择
1.4.2 温度影响试验
由图4可知,随着温度升高,膜通量逐渐增大,有利于提高分离速度,这主要是由于温度升高,料液的粘度下降所致。
由表1数据可知,采用纳滤方法处理头孢唑林酸结晶母液,对结晶母液上清液和滤后液均可实现头孢唑林酸的有效回收,在浓缩倍数为5倍时回收率为90.3%~93.7%。 2 费用效益分析 在已知生产规模的条件下,可采用改良朗格因子法计算设备投资额[3]:
由此可估算出唑林酸回收所需膜装置的投资为222万元。
3 结论 ①采用纳滤分离方法对头孢唑林酸结晶母液进行处理,可以有效回收头孢唑林酸结晶母液中残留的头孢唑林酸,头孢唑林酸回收率90.3%~93.7%。 参考文献: 作者简介:向连城(1962-),男,湖北恩施人,副研,北京朝阳区安外大羊坊8号,中国环境科学研究院,电话(010)84915314。 |
