Biodegradation of 2,4-dichlorophenol in an air-lift honeycomb-like ceramic reactor
论文类型 | 基础研究 | 发表日期 | 2014-10-14 |
来源 | Process Biochemistry | ||
作者 | Quan,Xiangchun;Shi,Hanchang;Zh | ||
关键词 | biodegradation immobilization honeycomb-like ceramic carrier 2,4-dichlorophenol phenol co-metabolism bioreactor wastewater treatment | ||
摘要 | A novel air-lift bioreactor, with a honeycomb-like ceramic column packed in the inner draft tube as the carrier for immobilization of microbial cells, was developed in this laboratory. A microorganism, identified as Achromobacter sp. and capable of degrad |
相关推荐
- Nitrifying Population Optimization in Municipal Saline Wastewater Treatment
- Characterization of the start-up period of single-step autotrophic nitrogen removal in a sequencing batch reactor
- RES EARCH ON MEMBRANE B IOREACTOR TREATING DOMES TIC WAS TEWATER AND RELATED MECHAN ISMS
- Micro-Polluted Surface Water Treatment by PAC-MBR Process
- Cr_3_改性膨润土用于处理特定有机废水的实验研究(英文)
- Kinetics of co-metabolism of quinoline and glucose by Burkholderia pickettii
