Bioadsorption of 4-Chlorophenol to the Activated Sludge
论文类型 | 综述,政策... | 发表日期 | 2000-09-01 |
来源 | 中国水网 | ||
作者 | WANG,Jianlong,Nigel,Horan,Ed.S | ||
关键词 | 42chlorophenol; priority pollutant; bioadsorption; activated sludge | ||
摘要 | The a dsorption be haviour of 42chloropheno l from a queous solution to activated sludge wasquantitatively characterized in this pa per. The effects of the initial pH values , initial chlorophe no lconcentra tionand adsorbent dos age on bioadsorption |
相关推荐
- 枣椰仁颗粒活性碳及其在多介质过滤器中余氯穿透曲线动态建模(英文)
- Micro-Polluted Surface Water Treatment by PAC-MBR Process
- A_O工艺与分段进水两种生物脱氮工艺的比较研究_英文
- Bioadsorption of pentachlorophenol (PCP) from aqueous solution by activated sludge biomass
- Highsludge高浓度活性污泥脱氮工艺中试
- Implementing Both Domestic Wastewater Reuse and Sludge Reduction by a Combination of Anaerobic Phase and Membrane bioreactor
